Submariner1
- Berkshire
I need to Cleanly drill 8mm Holes through a 25mm deep (dense rubber) Ice Hockey Puck.
(Changing to bigger rear wheels) so need to raise the front AV Pads)
anyone ever drilled this kind of material?
- only ask as I don't have any spares, so would rather know before; if one needs any special type/profile of bit?
- Is this better drilled at high speed or low speed. I assume low speed? To avoid melting or will that grab rather than cut?
Only got a small pillar drill and usual HSS steel drill bits, and some cobalt drill bits for stainless.
the discs to be drilled are in photo below under the wheels.
"fire fire fire"
