finyuk2005
used this trick recently on an international tractor injector pump shaft seal, saved taking the whole pump apart! a bit fiddly but it did the trick!Looks similar to the input seal on a Jag diff. I drilled a couple of holes in the seal, wound in a woodscrew and used a slide hammer to pull it out...
the lad thought his tractor was totally ******** when it started spewing diesely oil out the breather, god knows how it didnt run away!!
