Adam Marshall
- Nottinghamshire England
I have put hundreds if not thousands of lifting lugs on over the years i have worked for this company. The 36mm diameter straight shaft ones with the end forged, standard ones you drill through the frame and weld with a plate on the back. Now we have a load of lugs ordered in with no straight shaft just a flat piece to weld to the frame so nothing is actually going through the frame. Obviously these will be welded on good but will they be OK on 8 yarders?
