Yeah I have a metric leadscrew with a norton box. I want to cut English threads.Metric change wheels? Aren't they just gear wheels, and the lead screw is either metric or imperial? Been decades since I did any screw cutting though.
If I have a 127T gear, and a full set of metric changewheels. What other gears do I need to cut imperial threads?
127 is better than 63.You need a 63t on the 140 not a 127t.
Advice on Lathe purchase
heres a few pics I have collected and the Name plates for a 140. Originally the working out of the changewheels and selectors took me ages and ages.Now as suggested I bought a 127T only to find it dont fit in the train or onto the banjo, probably why harrison supplied lathes with a 63 and the...www.mig-welding.co.uk
Except if that post is to be believed it doesn't fit on the 140...127 is better than 63.
It fits on an L5. That’s what I’m taking the gear off.Except if that post is to be believed it doesn't fit on the 140...
Yes but the point is that it doesn't fit on the 140. I have an L5 so I can't verify that, I'm just going on what others have said.It fits on an L5. That’s what I’m taking the gear off.
Yes it is vastly different. Because the L5 has an imperial leadscrew and the 140 has a metric one.If the graph is to be believed, that has come off the L5 with a two lever norton box. Then I can go 50, 40-60, 127 and get the majority of pitches.
unless the ratios are vastly different on the norton 3 lever box.
It fits in the L5 though. The cases are exactly the same.The 127 wont fit in the casing
that is why I made the 63
the error is very slight compared to a 127
both are a compromise
I do cut lots of imperial threads with mine
A 140 has the same casing as a L5Yes but the point is that it doesn't fit on the 140. I have an L5 so I can't verify that, I'm just going on what others have said.
If it _does_ fit then I calculate it I think 40-60/50-127 would be about right (settings on the norton box as per the charts above).
