My dimensions are correct, I think everyone is misreading the drawing.
my apologies!I will admit to that![]()
my apologies!
Should be a MckIta surely...makita 18v tool hanger
i also have the battery holder
milwaukee m12 tool holder
milwaukeee batter holder
Yep it was confusing as where it will sit are two sizes of wooden rail. I measured using the Vernier and saw the first hole has the be 50mm from bed. Translated that without checking where the blade fits. But.....as I said earlier the model you showed would be perfect anyway if the holes/slots were as close to the the blade as possible and 115mm apart. Do you still have it or is it totally converted....lolThank you. I researched the spec on utility blade sizes and discover you can't place a hole 50mm from the tip of a blade 62mm long. Having modeled that and a mockup of a holder, I decided rather than waste it, I went on to make a low profile holder for scraping the bed.
The printer bed that is!![]()
If you have windows 10 you can load the STL files into 3d builder for a quick and dirty edit, like lengthening handles and such, has saved me loads of times when i have found a model that suits all but for a small edit needed.
Everything else i have tried to use to edit STL's either hasn't worked properly or is way too complicated to use for me.
Cheers mate. I will get it printing shortly.Blade holder and clamp.
<edit> added the sketchup file. I made the minimum distance between centres 113mm (just in case) and thickened up the body.
If you wanted it to be stronger you can add more perimeters rather than infill. Supported areas look OK to me, I've seen (and printed) worse). After all, it's functional rather than a contender for most beautiful print.
As others have said infil seems fine. It's functional as opposed to strong part.Finished, it'll do. Only 10% infill which is down to my boy not me. Seems very lightweight. Took about 6 hours. @ukracer, what would you do this at infill wise, how long would you reckon it'd take (1.75mm filament)?
These "ragged" areas were supported. The quality is to my mind a bit carp. Be interested to see other people's "supported" faces.
I'll make the copper strip inserts tomorrow hopefully.
Printed the STL mate. Just been busy over the last few days. It printed mint.Blade holder and clamp.
