ok i had to repair a stripped thread so i drilled it oversize then inserted a 10mm bar and welded it both ends now i need to drill it in the center for a 6mm hole problem is the bright bar i used now wont drill couse its to hard .i havent got a clue were the bar came from just some i had lieing around, are there any special drill bits that i can buy or any ideas
im gonna try a TCT bit to start one suatable for stainless steel this quick faviour job is gonna cost me time and money
.....hope u sort it !
ithe otherone is a pig
i couldnt tap it or pre drill it as there was only 2mm wall thickness after tapping and the hole would have filled with weld and theres only acces from the outside for a tap wrench gonna get the dremmel out on the otherside with some stone wheels and take as much weld of then try and knock it through but will have tpo knock it from the outside and cut bits of inside as i go couse its to loong to come out in a oner
