not conversant with tha lathe but on my Myford and Student I have a Dickenson type quick change tool holders....they are not cheap anymore......View attachment 277302
Im assuming thats the type he has with 32mm post as part of the compound.
Most qctp's have about 15mm bore.
Any specifics? Not sure whom/where for that.Order a create tool post from China but ask them to put a 32mm bore in it
As above.View attachment 277329
Fitted mine with no modification to the top slide. Can use a 12mm or 1/2" tool unlike on the ml7 which is restricted to 10mm FWIW the tool holders from Chronos are a nicer fit than the ones from RGD. I probably have better photos somewhere but that it the first one I found.
Edit:
Slightly better.
Edit2: Originally mine had the Myford Drummond four way rotating tool holder which was directly replaced with the "Dickson Myford type " from RGD
Create Tool make a copy of the Swiss type Multifix toolholder.
They’re based in China. Make real nice stuff.
they will do custom work.
This one 4PC QUICK CHANGE TOOLPOST TO FIT MYFORD but your stud is larger and I can not exactly remember how it comes out of the top slide, I am pretty sure it is staked with a small screw from beneath then just unscrews. Should be easy enough to make a new one, I would have a look but I can not get to the lathe just now.Do you have a link for the one you ordered?
That's the one. The Norman toolpost & holder.
