Thanks for the suggestion DAPPH, I had thought about adding matching clasps to the top of the box like you've said as it's probably the best solution.Just had a thought for future things perhaps ...
The stirrups in the base are OK , a small keeper block to one end could hold the knurled screw to stop rotation and a shaped single or pair of wooden stirrups in the lid covered with the same material as the lining would hold every thing in place when the box lid is closed
Thought ....... for cutting the teeth on the blade , you have a lathe , tail stock & a live centre ? Set it up so the tooth cutting hob blade is midway on a thick 18 inch long bar supported by the chuck & the live center in the tail stock or perhaps better still between centers . Set the teeth by hand ( long boring job on a 10 inch fine toothed back saw )
Clamp the blade flat between square steel bars such as 15 mm square key steel bar set it so it is parallel the bed & on the axis at both ends
Use a cross slide stop to set the tooth depth and the carriage dial or fit an indicator plate in degrees for carriage travel to make the pitch .
Write out a simple cutting chart and tick off each stage of tooth cut when it is done
That is a terrible shame and in my opinion very short sighted of your current employer. You are obviously incredibly talented, a talent which should be nurtured and allowed to grow, not held back.Thanks for taking the time to look through my builds so far, this will likely be the last one for the foreseeable future as my work has put an end to any private work for insurance reasons. I'm hoping to sort something out in the summer so I can continue with my passion.
Could I also congratulate you on your photography, superb pics. Do you use a decent camera or just a phone?
If you ask nicely there may be someone on site ( not me ) with a small home use lazer computer controlled cutter who may be able to burn out those etching masks for you once the design is agreed , sadly it's not me ( just yetThanks so much for the comment Danzac, can't tell you how much I appreciate it.
I got into woodworking because it was something I loved and had a passion for but the world is a changing place.
I can understand the decision, its a much more corporate company and has to safe guard it's self, it just sucks for me
Especially coming from a much smaller business where I had a lot more free rein and encouragement to try new things.
Did my back in lifting it though!
