Mince and tatties
- Scotland
When I’m setting the parameters on my welder I select the voltage along with the wire speed. How do you know how many amps it creates when there isn’t an indication on my machine of how many Amps the volts and wire feed create.
I need to be aware of this because when I go to read a weld procedure it tells you the scope of amps that are required for the Job. I’ve always just went by the volts and wire feed speed but I just don’t know how to calculate the Amps through it
