They are an exact copy of the Eberspacher so the same sizeNone of these look like a professional solution though. Also they’re quite bulky, I’m gonna be short on space in the van
One thing to think about in van is a fail safe so they don't run when on the move
Maybe its just wasteful.Whats the problem with one running when a vehicles moving. There is no mention of this in the eberspacher manual. The opposite is mentioned when a heater is installed in an ADR vehicle that a forced shutdown is required when the ignition is turned off
“Forced shutdown in ADR / ADR99 mode (only for diesel heaters)
In vehicles for the transport of dangerous goods (e.g. tanker trucks), the heater must be switched off before the truck drives into a danger area (refinery, fuel service station, etc.). Failure to comply results in the heater switching off automatically when:
• The vehicle engine is switched off.
• An additional unit is started up (e.g. auxiliary drive for unloading pump etc.).
• A vehicle door is opened (ADR99 regulation, only in France). The fan then runs on for max. 40 seconds.”
Just watch what you’re buying second hand. A few of the HGV ones are brand and model specific. Ie part of the bits needed to run are in the truck and not the heater.That’s what I want to do.
sitting in a Mercedes sprinter that wouldn’t heat up on breaks during a -2° night shift soon gets you realising that a heater would be money well spent.
Noisy buggers though. I doubt I would sleep anywhere near one.
Our runs flat out permanently. Probably helps keep it clean. Running on kero helps as well.When the eberspacher d2 is on Max there is a fair bit of noise but once it’s up to temp, air flow and fuel is reduced and then it’s difficult to hear if it’s running
Hello, anyone near you with oil fired central heating? I use a Lidl oil transfer pump to fill up a couple of 5L cans. Last lot of kero I bought was about 30p per litre.How big a fuel tank do you run? I’ve not bought kerosene/paraffin before, only red and white from the local fuels supplier
