I need to put a bend of about 45 deg from flat into some bucket edge hardox 20mm thick x 150mm wide. Only need 4 bit doing.
I can either:-
Use the local machine shop
Use a 7 tonne hydraulic splitter
Cut & weld
Preferred method is to use the splitter.
Will 7t do it?
I might be cutting it down to 20mm x 75mm which I assume it will bend easily enough.
The cutting will have to be done at the shop as I dont fancy cutting 100cm with a 1mm cutting disc & my plasma wont cut that much.
This bit in yellow
I can either:-
Cut & weld
Will 7t do it?
This bit in yellow
