mdr
Collector of welding machines
- wye-on-earth
That looks poxy that dinse connector.Santa has come early! Will it improve my TIG beads? No but at least it's definitely my fault now!
Does the dinse connector rapid sent me fit?...
...nope. Right size, goes in, but will not turn. Poorly manufactured. Maybe I can file it to fit!
I wish you wouldn't sugar-coat your opinion.
You're right. It's a bit...shi..."cheap" shall we say; especially next to the CK super flex. I looked at eBay, Rapid, and R-Tech and they all look to come out of the same factory. I got bored looking and bought it.
If you see a nicer one ping me a link. It has to be the smaller dinse (9mm, 16/25) to fit the welder. I could step a larger dinse down to fit but that's just adding more bulkiness to the front of the machine.
I dont think I can swallow that right now . but there must be something better than the carp I got ?. maybe a flat switch and clip on holder from rapid .
When you bought the totch from R tech, did you get ck bits and bobs too or cheapies. I have two ck torches a 9 and a 20. One came from rapid with ck cups, collets etc. The other rtech. You can tell the difference in the quality with the cheap cups, collets etc. Both work, was just disapointing buying a quality torch with cheap bits.mine came with the torch made up from r-tech so not to bad , the ck switch is £50 ish tooI dont think I can swallow that right now . but there must be something better than the carp I got ?. maybe a flat switch and clip on holder from rapid .
Any comments as to the quality of switches and cables.?
but i can wrap the hose around my arm multiple times like they show in the CK adverts, and that's what i wanted, a small very flexible hosed torch.how many amps can take one of these?It's a wp9 sized flex head torch,
