Suspect I blew the headgasket of our Panda, so made a adapter to put airpressure in the sparkplug hole.
Then discovered the hexagonal was too big so milled it two millimeters smaller.
Then added a piece of metal tubing to be able to push in the hose when mounted, and depress the blue ring to pull the hose out
when done.
Tommorow I will replace the thermostat housing and then I can test for headgasket failure.
when done.
