stuvy
Bohler Uranos 2200 AC/DC will give any top end machine a run for its money, without a doubt. DM if you want some details.
will it weld brass? Couldn’t see it in the spec list
If local support is important to you, rather than buy online, consider Wasp Supplies in Luton.
I can’t look at that name without thinking of this....Bohler Uranos 2200 AC/DC will give any top end machine a run for its money, without a doubt. DM if you want some details.
Yep, it'll weld pretty much every material you can think of.will it weld brass? Couldn’t see it in the spec list
Not hard to use exactly, but the settings are all in background and sub menus.what makes the miller hard to use brad?
All the inverter machines mentioned so far are full function AC/DC machines with pulse settings and everything adjustable, so if there's a TIG setup that works, then it will work on any of these machines.Not hard to use exactly, but the settings are all in background and sub menus.
not like the European machines such as Lorch and EWM, where everything is depicted on the front panel, slope, peak, background, post flow, etc
Oh it’s all there no doubtI always thought the Miller DX setup was very logical. Columns of buttons to sort certain functions. Polarity, Output, Pulser, Slopes, and Gas timings. All right there on the front. It's just laid out a little differently than the european style of a graphic layout of the sequence.
