- Never Never Land
Also today I made a little rocket stove. Using some 100mm box that I was kindly given by a customer I work with at work
I regret not Mig welding it but here it is stick welded.
Capped the bottom using some left over steel from the roller bender
Made two little feet from some left over steel.
I thought it would fall over easily so I put loads of crap in the end to see and it stayed upright so that’s good.
I need to make a vent door for the feed pipe and flare the ends but that’s about it and that’s also done
. I regret not Mig welding it but here it is stick welded.
. Didn’t see it being a problem but worse ways I’ll make an opening down the bottoms side so it can be lit a bit easier.
I’m so slow
