bigegg
- Leeds, West Yorkshire
Domestic consumer units:
Is there any sort of consensus on good makes? Or ones to avoid?
Also:
For the space I have, I could ideally do with a vertical, commercial style unit.
Is there any reason (apart from self closing flap) to NOT fit a domestic unit at 90deg to the usual direction?
If not, again, is there any recommended commercial brands, or ones to avoid?
(I'm assuming that I'll still be able to fit single phase RCDs, rcbOs etc in a commercial unit?)
I have around 1m vertical height, but only 300mm width to play with at eye level unless I have the meter and incomer moved.
(If I fitted the CU up near the roof, I'd have 500mm high X 1m wide - but 7ft up)
Also:
