mdr
Collector of welding machines
- wye-on-earth
Mmmm it is only 130€ more (599€) and in you opinion is better than the Stahlwerk.
https://www.comercialdistrival.com/tienda/soldador-sherman-digitig-206p-ac-dc/ Only the welder
And with accesories https://www.comercialdistrival.com/...tig-ac-dc-206p-botella-manometrotungsmascara/
If you think it is ok it is ok for me. I have no exprience.
Aye but the Sherman 206p is probably not much bigger than your stick welderFor me...mobility. I wouldn't like to have to drag the TIG to an outside job and pull my back. Long leads may work but a mini arc welder is super light and portable...
(The TIG is currently wintering in a spare bedroom (aka "dumping ground"))![]()
Look into local supplier of shielding gas, it’s not cheap in the small bottles,
and you will pay rent on the larger ones, they are bulky and best suited in
a trailer.
Welding aluminium will require a pure argon, which is no good for mild steel.
I would advise a tig welder for aluminium, it needs to be AC, with frequency adjustment.
There are many multi process welders, some do mig and tig.
look at R-Tec
