Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
See what the MOT man says and order some coils..
How could that affect the height of the suspension?
Can only just get a trolley jack under.
what makes you think they have failed ,,, just asking , not being funny
did you stand the shocks up right before fitting and move them a few times ,, some old shocks like that , it primes them.
. are they the same length as the old ones and not shorterJust seems the ride height has dropped since yesterday.
I would be pulling the shocks again to be sure that one hasn't failed or jammed upThat’s a mistake I have made several times over the years, and only remembered after fitting..... It bleeds the shock internally to make sure the air gap is in the right place, and the oil is where it should be.
Get it wrong, and you have minimal damping, and/or you get squishy slurpy noises and poor damping.
Best to fully compress and fully open several times while upright.
Errghh, I ordered them from my numberplate, as a reference, and the company, knows exactly what my car is from the internet database like DVLA in the uk, I've checked and everything corresponds.
Bingo. I suspect you have removed Nivomat self levellers and put normal shocks on. Pretty common mistake.
On a nivomat, part of the load is carried by the shock, so a soft spring is fitted to carry the other part of the load. In service, the motion of the shock, allows it pump up to the preset ride height.
Take this away, and you are now reliant on a spring that was never designed to carry the full weight. Car now sits low.
I know this, as my company offer conversion kits for a number of cars, to fix this very issue as nivomants are crazy money. But not any Volvos
Your only fix is to get springs from a non self levelling model.
Im not THAT up on volvos, but some certainly use nivomats. I see this issue daily on forester, sorrento's, santafes, cruze, etc, etc.
Result then - pair of springs and another morning under the volvo - how could you even doubt the Monroes?
original one was leaking , hence the mot fail at the start ..Glad you found it - it sounded strangely familiar to my issue with the Subaru. Forums pointed me to some Australian springs for that car - easily obtained and it was back up - but lost the levelling, meaning the previously wonderful trailer and caravan towing was now less wonderful. But when shocks were several hundred quid each!
Quick solution is to put the originals back - and then go hunting for heavier duty springs - or start saving.
Annoyingly for me, if I had the self-levelling pump up shocks on my Challenger, I coudl have left the original HID lights in for the IVA test when I imported it . . . as it didn't I had to fit different lights.
