brightspark
- yarm stockton on tees
replacing core plugs on an old engine what would you do to make sure they had a good seal . a Loctite b jb weld c other
If you make a stepped punch to fit them, leave a good internal clearance for when the core plug closes up. I can still hear my Father laughing at his mistake!
Clean the block up well.
Chill the core plugs in fridge, a smear of blue hylomer.
Using a socked drift them in.
Or this does as well.
https://www.ebay.co.uk/i/2643376124...-fpRhqE07HJmM7YSiaiFkjwDrY4CG9HgaAnwOEALw_wcB
To lazy to go and take a picture of my kit.
Works for me.
Ooh I like, another thing for the 'one day' list...
Yeah, agree, but one day when you need it...I can almost guarantee most of that set would sit on a shelf unused!
Best made to suit when needed. Shiny though!
Works for me.
You're doomed now John, there will be the inevitable comparisons of tightness!In the dim recesses of what passes for a brain, I recall if you really cleaned the block a new plug [which was slightly convex] used to be fitted by giving a drift held in the middle a belt with a hammer, they were a tight as a crab's rectum at 500 fathoms.
With all the rubbish coming out of the far east, I would suggest that you check that your freeze plugs are in fact brass by filing an outer edge. A few years ago I replaced the plugs on my Kubota tractor and they didn't last a year. The plugs from the tractor dealer were pot metal with brass plating.replacing core plugs on an old engine what would you do to make sure they had a good seal . a Loctite b jb weld c other![]()
I've not heard that one before, but I like it.In the dim recesses of what passes for a brain, I recall if you really cleaned the block a new plug [which was slightly convex] used to be fitted by giving a drift held in the middle a belt with a hammer, they were a tight as a crab's rectum at 500 fathoms.
