with a 1kw element. it will reach 300cHow are you heating it? Following with interest!
Have you a link where to find it .with a 1kw element. it will reach 300c
That’s what I have in the cabinet which houses the brain for the CNC. 5w bulb on 24/7Does it have a temperature control and thermostat ? Ours just had a 40 watt bulb in it and was left on all the time.
the element came from ebay about £7 you just select the wattage and length. they come as straight lengths and you just bend to shape.Have you a link where to find it .
I would like to build something similar
sorry didnt take any as a made it. but its a 150mm x 3mm tube with the element in the bottom a wire mesh over the element that the rods lay on. i welded 30mm bolts on the outside as spacers and fitted it into the box and filled the gap with glass fibre insulation. the thermosat probe is in the top of the tubeNice. You got any pictures of how it’s put together please?
