mangocrazy
Italian V-twin nutjob
- Sheffield, UK
Let me explain further. I need to bolt my Lancia Beta 2 litre engine (without gearbox) to an engine stand. In the past I've bolted the engine to the stand using chunky M12 bolts into the bell housing. I now need to work on that end of the engine and the only suitable fixing points I can find are 4 x M8 threads arranged in a 70 x 38 mm rectangle (used to mount the drive shaft on).
If I use 10.9 high tensile bolts will they do the job without failing? I will be making up an intermediate plate in 12mm steel plate to bolt the plate to the engine on one side and the plate to the engine stand on the other, as the cutouts on my engine stand mounting plate don't line up with the mounting holes on the engine.
I've tried looking at tensile load and resistance tables on t'Interweb and my brain hurts. According to one search result, a 10.9 M8 bolt can hold 3,040 kg. I presume this is dead weight in a vertical orientation, not what I'm hoping to do.
