la bombe citroen
Evening chaps,
This is probably a silly question, but your help would be greatly appreciated.
I need to do yet more welding work on my Peugeot 304 project this weekend, so I stopped at B&Q on the way home to pick up a sheet of steel. The problem is they didn't have any of the usual 1mm mild steel sheet that I normally buy, so I picked up one sheet of 0.5mm steel and another of 1mm galvanised steel.
The question is can I run a flap disk all over the galvanised sheet to remove the zinc coating, etc, and then treat it like a normal sheet of steel for welding purposes (ie: not risk the usual galv problems).
Secondly, am I right in thinking that even my small Clarke Pro90 mig will obliterate the 0.5mm sheet?
Any advice very gratefully received
