It is an up and over roller door and has a turn handle lock. Its key is just like a front door with an number of cutouts that operate the tumblers( if that is what they are called) It was fitted before I bought the house and I have lived here for 14 years. Over the years it has worked OK but now and then it refuses to turn open. I used WD40 and normally that worked. But today it has not. I have a second key and that does not work also. So I think the barrel has worn to the point that the key cutouts dont fit the key profile anymore as they should. So the only solution I can think of is drilling the barrel but will that be enough to be able to get the lock mechanism to work? Will normal drills bits do the job?
you can have one of ours! Please
