clem dog
Its just not fair!
I just bought a second hand 300 amp single phase mig.
Havent had a chance to use it yet other than to see if it fires up and feeds wire, which it does!
Its a citoarc m 300 c solo mig. There was some overspray on the front panel which i triad to rub off with thinners and managed to take the settings off also
Regarding the voltage settings (as I have no manual) could I use a multimeter, between the tip and earth clamp, at the different switch positions to obtain the relevant OCV's? Then I could use the miller calculator and I would then have an idea what thickness of steel could be welded with the 1mm wire that is currently in the welder.
Can anyone shed any light on the set or know where i could get a manual for it as the previous owner had lost it?
Ill try and get a few photos up of the welder and a few sample welds before the weekend for you guys to run your eye over for me!
Clem
.Regarding the voltage settings (as I have no manual) could I use a multimeter, between the tip and earth clamp, at the different switch positions to obtain the relevant OCV's? Then I could use the miller calculator and I would then have an idea what thickness of steel could be welded with the 1mm wire that is currently in the welder.
Clem
