pondy
- chedburgh, suffolk. uk
hello, i got a fiac rd3150 comprsssor, its about 7 years old, around 150-250 litre, its been sitting around a few years and got it as a project as it didnt have a motor, got a new motor etc and set it all up tonight, it will run fine but will not show an presure on the gauge, there is air leaking slightly from the valve on the metal pipe between the pump and the tank and there is another small valve on the bottom of the main on and off switch, it has a plastic push fit pipe going from it into the tank, this has a small drilling inside, air is leaking worst here, have removed there and the valve moves fine, the pine apears fine to
what should i look for, re stipped and clean again, could the pump turning the wrong way cause issues? it does build up some preasure but gauge dont move. could a sticking valve on the pump line cause this
need some help as i dont know anything about these things
sam
sam
