octo0072000
- south yorks
Your right, wasn't so bright this morning.
if it's right hand thread it's anti clockwise also depends at what end you look at
What it really needs is an isolating crane valve between the tank and quick fit connector for starters...![]()
I was going to put a 90 deg. Street elbow , then a full bore stainless ball valve but they dont do a male and female, only Female Female , so would need a nipple and that ends up with a lot of hardware on the end.
Its 1/2” BSP . The non corroding QR is High Flow EuroIs the tank entry 1/2" or 3/4" ?
You can get a few pipe fittings on and it will be OK
ThanksRadiospares have a full-bore 1/2" BSP valve with male/female fitting:
https://uk.rs-online.com/web/p/manual-ball-valves/1385645/
