julianf
- devon, uk
I have the top to a wadkin AGS 250 table saw.
One of these -
Its a lump of cast iron -
...and its been sitting in out hallway way too long!
As you can see its got the oval cut out for the blade, and two slots for sliding mitres etc.
I also have the fence mechanism, but kind of had plans for that elsewhere.
I wanted to turn the table into a router table. This kind of thing -
But its not ideal, in that the oval hole is too small to use as-is, and longer than standard router insert plates. Which isnt really an issue, as i can make up a custom plate, but it just starts feeling more and more like a bodge.
Plus, Im not 100% sure how, say, a 10mm, plate will work out. As in id need a lip for it to sit on, and ive not yet calculated if id still have that lip, after removing 10mm for the recess.
So, my question -
a) do you reckon a router table is a good idea / would work, or
b) what else should i do with it? Id consider floging it, and, sure, to the right person it would be hundreds, but as a lump of flat cast with an awkward oval hole, i cant see it being more than £50 or so, so its hardly a big money item.
Basically, any ideas that get it out of my hall way, and im all ears!
Thank you.
One of these -
So, my question -
Thank you.
