Ashley Burton
- Northamptonhire
Not cheap those!Need some hd drawer runners now.
Only need 25 kg so not too bad. Or il chop up some chopping boards and make somethingNot cheap those!
What's that?I found another one.
Stupid money
https://www.ebay.com.au/itm/Gurgling-Guts-Eyes-Retro-90s-toy-4kidz-Inc-/282649144206
I just have the brain and eye to look for now.
View attachment 255174View attachment 255175 View attachment 255174 A 5 inch tailstock for the rotating table. However, it needs to be 51/4, I assume tilting it up won't do it?
I have Ariel by C.W.Waller too from when I had a Red Hunter, covering 1933 to 1950:The Neill's are excellent books. Got a couple in my collection.
I often think that this pipe coiled in a filled water tank tucked in the corner outside would be as good as it gets regarding heat exchanging...ive found in the past even going through 10M of copper pipe the air is still warm and moist (ooer![]()
10 meters of 8mm copper pipe and T fittings, plan to make a compressed air heat exchanger to go between pump and tank, compact as possible so it can remain permentently fitted and still portable.
) if just exchanging room tempsWell, yesterday, to be exact. A Dell Precision Tower 5810, (and a new Asus 24” monitor), 64 gig ram, and a terrapin of storage, a graphics card with bigger capacity than I knew possible, and fusion 360 (sadly for personal use, not professional).
Only a terrapin, I think you will need a turtle of storage to run fusion 360![]()
