well only managed to get a few bits done on saturday.. I was figuring out how the pervious owner managed to get .8mm wire through a .6mm tip
so changed the tip for a new one and carried on with a new roll of .6mm wire. The current was set too high to begin with and I was also using .8 wire on 1mm sheet
there were more holes that weld
the lap joint was with .6mm wire on the lowest setting...might bump it up a bit because the penetration's only just showing.
anyway here's the pics
there were more holes that weld the lap joint was with .6mm wire on the lowest setting...might bump it up a bit because the penetration's only just showing.
"oh that's nice luv!"
