I've bought the above shear off Ebay. The ebay seller ID is j4s_r2h5aqhsd-9 which is of course a Chinese company but they were advertising the stock from the Czech Republic. £64.99 delivered.
I fancied getting a shear to cut aluminium and also to generally cut down on the amount of metal dust in the workshop from saws and grinders that might damage my machine tools and welders. The fact that this shear was cheap and looked very much like the Makita one they charge around 300 quid for also played a consideration.
Ordered late on 28/09/2020 and delivered today 01/10/2020 just before lunchtime by UPS. The delivery was much quicker than advertised. I would have been very happy about this if UPS hadn't sent me an email on the 29th saying they were going to deliver on the 30th.They resheduled it by email at half past six that evening after I had been expecting it all day. Just as well I work from home.
The shear arrived in a taped up white box, OEM fashion. No padding whatsoever and the box was a bit battered. The allen screw on the side of the foot had poked a hole through cardboard box. There was no damage that I could spot fortunately. This is the box after I tore it open. The box damage was in the bottom left corner but the photo is only there to illustrate that there's no protective padding.
The shear is double insulated which is just as well as it only comes with a 2pin plug and no earth. A UK adaptor is supplied.The cable is 2m long so you might have trouble cutting 8' by 4' sheets out of the box.
This is the shear next to a genuine Makita Nibbler. I know they are not the same tool but they share a the same lineage so I still think it is handy for a side by side comparison. The aluminium casting on Makita is smoother. The foot on the clone is quite a scabby casting. (See later picture). The electric motor and gears sound very alike on both machines. If you have an 1980's Black and Decker corded drill or similar you will recognise the high pitched whine. When the trigger is squeezed there is no noticable difference in vibration or smoothness. The cheap one does not feel rough in comparison.
This the bottom of the foot on the shear after some test cuts. The casting has picked up some aluminum already. The splodge on the casting is a bit of a curiosity and the two hardened cutting teeth have a bit of a poor alignment There is some adjustment of the bottom tooth to line it up correctly. I gapped the teeth to 14 thou. (Edit. I Guess the splodge is where they cut the sprue off the casting.)
There's some aluminium rubbing evident on the top tooth butIthe edge is crisp. I've done the Forged in Fire file test and the teeth are very hard as expected. I think we might be at the mercy of the foot casting for tooth alignment though
Continued......
