I have no idea but from images I have seen on eBay it looks like it can only be removed after the radio is removed.Claw hammer?
Does the bezel pop off?
May reveal holes to release the the clips
There's got to be some retaining clips down the side to release it
I'm pretty certain they're a standard double din unit. As I'm sure I've seen the same dash with a single din & a cubby underneath!
Why do you need to remove it? @Hood
This is a 68 plate but seems to be a 2017 model, seems Citroen do that when they bring out a new model, they still sell the older ones but at a discounted price.@Hood I had a later 2016 Peugeot & the headunit was great & the handsfree!
I think @eLuSiVeMiTe is on the same thinking as me! There must be a guide on the interweb somewhere I would have thought
Ha ha the dealership are gangsters or at least they were back in the days when I had BX'sId be running a putty spatula down both sides of it.
Failing that go talk to your local dealership with a pack of beer.
In the pic below the blue arrows seem to show how it clips on to the radio itself and looks like it would be impossible to remove prior to radio removal.
There are also vertical tangs on the top (red arrow which go down into the dash top by the looks of it.
There seem to be metal clips (yellow arrows) that may hold the unit in but not sure how they would be removed, possibly a thin blade being inserted would do it .
Can't find any info either.Ha ha the dealership are gangsters or at least they were back in the days when I had BX's
And yes that is what I will try but was just hoping someone knew before I broke something.
Thanks, I will try with something like that and seeHad a quick scan through some French forums.
You need a bank card down each side to release the clips, seems similar to a C5, if that helps.
Bloody hell, you French (and incommers) must be rich, 4 BANK CARDSMaybe 4 bank cards two each side too and bottom.
?Android GPS thing it says.
