Tangledfeet
Knurling is my Nemesis.
- Top of a hill above St Andrews, Fife
TIG'd a butchered gas bottle key on the end of a T-bar this evening. Typically overkill as ever, but then I'd never want to disappoint!
Made a hand guard for a small torque tool.
This is for protecting hands while working close to high pressure hydraulics.
View attachment 252012 View attachment 252013 View attachment 252014
Didnt they have those in Blake's 7?
If I remember a previous thread correctly, get a cold shower.![]()
How ........... Redskin !TIG'd a butchered gas bottle key on the end of a T-bar this evening. Typically overkill as ever, but then I'd never want to disappoint!
Is the key for the lathe carriage lock or the locks on the rotating compound slide?
Not strictly "made today" but I've made five of these over the past few weeks for the missus. She loves gardening but constantly bending and reaching out is getting difficult for her - so we are moving some of the garden up to "waist height" for her.
The first planter, the prototype is 1 metre long. I then made a 2 metre long version - and then a 1.5 metre version (Shown above). Then she asked for two 2 metre long planters to go under the windows at the front of our bungalow. I finished the second one a couple of days ago.
This is a 2 metre long planter outside the greenhouse. They are all made from 50mm x 50mm x3mm angle, with a bit of 50mm x 3mm flat for the centre rib and the feet. Wood is 4" x 1" sawn.
The latest 2 metre planter. I made the wood finish a littler darker on the last two of these. The frames are sprayed first with cold galvanising paint and then two coats of black Hammerite paint. I run the wood panels through the planer/thicknesser on one side only. They are then soaked with a solution of BlackJack thinned down with white spirit, with a preservative mixed in too. The planters are then lined with weed suppressant membrane before filing with a mix of compost and sharp sand.
The latest project is a 1.2 metre octagonal planter . . . . .
Malc.
How long will it take to look like the Statue of Liberty?View attachment 251962 View attachment 251963 View attachment 251964 So we’re progressing with the pergoda,time for the top sheets,with 2 left off for hoisting,you can see where I’ve clenched over 2 strips per sheet to fasten underneath,looking at @gaz1 videos I think next time I can use thinner than 0.7mm.The loose flaps will be glued from underneath.
Nice work, should certainly last longer than the one from the garden centresView attachment 252029
Malc.
I thought it was a corkscrew then I looked closer and am now baffled. Ti's beautiful
my two cents worth. Skinned the punt today
Both hull plates tacked and fully welded in, both side plates and transom completed. Good progress today, but the big items (hull plates)always make it look like the job is moving along very well! We have the keel cover to weld in, the two planing strakes and the doubler plates for the hull at the front, to do tomorrow and hope fully turn it back over in the afternoon. By the way 'Francis' performed well today![]()
Hope it’s never needed, but I think I would put a flat return at the top. The way it is now you run the risk of diverting high pressure fluid and fittings up and into the operators face
