MoreWellie
- Warwickshire, UK
Unfortunately whether it is a car, house, shed or shop the scrotes will know an easy and quick way into it and there is very little that is truly secure including bank vaults
Do the scroats look at the chassis before relieving you of your property?![]()
just the doors is the fave trick at the moment.
Back to the quickshift kit: new selector bush and alloy spacer plated fitted:
New alloy selector turret:
New longer selector mechanism fitted and selector bias springs adjusted:
All together with a new set of plastic gear knobs replacing the worn leather ones, I may change them in the future but will do for now:
Just my lighter clutch spring to fit, will leave that til I have a bit more strength back. Will get the wife to do a test drive tonight with the sllickshift and smaller steering wheel - should make driving a little easier once I am allowed to.
What sort of money is this widget?Ive got one too, almost car like gear changes afterwards![]()
https://www.onlinegearboxparts.com/product/defender-lt77-slickshift/What sort of money is this widget?
Pretty reasonable.
I’ve a pair to go in mineThat's the £100 heated leather RX8 seats fitted to the Landy, makes it almost comfortable
View attachment 303087View attachment 303088
Pah for £100 I landed a complete set of 2004MY L322 (all 5) and with a little fabrication (for the rear ones) got them all fitted. Actually find it more comfortable than my 2011 4.4TDV8 L322. Just need to get around to putting the V8 into it to make it go like the TDV8That's the £100 heated leather RX8 seats fitted to the Landy, makes it almost comfortable![]()
What's the leg room like with the L322 seats?Pah for £100 I landed a complete set of 2004MY L322 (all 5) and with a little fabrication (for the rear ones) got them all fitted. Actually find it more comfortable than my 2011 4.4TDV8 L322. Just need to get around to putting the V8 into it to make it go like the TDV8
Usual occupants approve
Way better than a standard seat - you have absolutely no hope of fitting them with a bulkhead behind them though.What's the leg room like with the L322 seats?
Not really, the snow foam just loosens road grime and removes the worst dirt before hand washing.Did the snow foam work in pulling the dirt off without getting up on roof and sponging?
You are pushing the mono block down with truck I see .............inevitable I suppose.
