Pigeon_Droppings2
- london
Welding rust will be a nightmare...easier to just cut it out. If you drop the lid in 5mm lower on the inside than the outside then run a nice bead along the joint I reckon it'll turn out very neat.
Belt and braces you could use a tank seal kit inside once welded up too.
I would save the inside edge/flange ...will make clamping a lot easier.
