hotponyshoes
- Somerset. Uk
Anybody know what thread these are?
Fitted to some fairly modern American kit
O/d of thread measures 4.1mm
Can't find my pitch gauge, seems to be about 7 threads per 6mm.
So roughly 1.16mm pitch which may or may not be about 21/22 tpi?
A 3/32 hex key fits pretty nicely
Hi Ponyshoes,
First off, I think your maths may be a little suspect.
If you have 7 threads per 6mm, then you have 14 per 12mm and therefore 28 threads per 24mm, so around 30 threads per 25.4mm (inch) or a pitch of about 0.85mm.
4.1mm is, give or take, 5/32" and both 5/32" (or No.8) UNC and 5/32" BSW have 32 TPI, so not too far out.
Does it screw into ally by any chance?
My maths is fine, 7÷6 is 1.16.
My common sense is not so good as it should be 6÷7 to get the correct answer of 0.85mm pitch!
It does indeed screw into alloy, how do I work out if its unc or bsw? Its American so unc?
1/4 UNC I would guess at.
UNC and Whit use different countersink angles. Whit are 100 and UNC 82.5
Bob
Thread flanks are different too, UN are 60* like metric (and have flats top & bottom like metric), BSW / BSF are 55* and have radii, that's why they're stronger...
Dave H. (the other one)
And don't get me started on BA...
Just googled that, I had no idea they were so confusing!And don't get me started on BA...
Just googled that, I had no idea they were so confusing!![]()
I'm more confused now!
No thanks, I'll stick to nice easy UN and whit threads, my lathe only pretends it can do metric threads anyway and certainly not multiples of 0.9mm![]()
