pity u weren't local its an easy fixunfortunatley not, I am not that skilled when it comes to welding / brazing. hopefully someone locally can assist
It may be just dirt, but the other side looks like there might be the start of a crack in the same place.
if u get stuck I will@brightspark ..if no one comes forward. Would you accept a parcel![]()
Cracking jobgot the conrod repaired today turned a temp pin to keep the fork in line . used the flamefast torch to get the heat up and used the oxyacetylene torch at the same time to braze it gave it a quick shotblast and a coat of 2k etch primer and its good to gopost it back on Monday
thanks for that10 out of 10 for that one brightspark !
...turning off behind this a fair depth (between the red lines 0.200 so 0.400 off OD) to enable me to shrink/loctite an oversized sleeve.
