Cheers.
Nah, hard times a comin, I'll just make do with shorter.Buy a new one.
Bloody right@Pollys13 Sorry, But that's a brilliant effort! I hope you don't make the same mistake when you replace it
I'll keep it as it is, not going to using it for sheets of ply. Axminster, will probaly charge a small fortune for a replacement, greedy so and so's.kettle calling the frying panBloody rightI'll keep it as it is, not going to using it for sheets of ply. Axminster, will probaly charge a small fortune for a replacement, greedy so and so's.
There is an extenstion box section that fits into it, cut through that as well.Just measure up the hole in the middle and see if you can get a bit of bar the right size to stuff in there.
use that then ready madeThere is an extenstion box section that fits into it, cut through that as well.
Um I have a friend with a mill.if you have a milling machine obtain a length of square aluminium mill it to the size of the box in the middle a tight fit and tap it home .3 inch either side should be enough to keep it parallel. Loctite it in as well you could also braze it with technoweld rods and a blowtorch on the outer surfaces and v a bit out
