doubleboost
- Newcastle upon Tyne England
It hurts to pick it up must be pushing 50 kgHow heavy is that lump?
The scrap price for bronze is only around £1.95 per kg.
I know it's not scrap but even so.
sometimes a repair can add to the look of an item and make it more interesting.Managed my first 2 bow-ties today. This is a bowl a turned about 10-15 years ago, was from a section (or cookie as the yanks call them) of sycamore. Not surprising it split, so insert 2 oak bow-ties to stabilize then I'll cut them back and tape it up then I can pour some resin in, probably use some copper powder in it. I'll probably throw it back on the lathe and re-turn it once done, maybe cut it a bit deeper.
It doesn't work and believe me the abuse I give one or two of them is quite severe.
Either that’s a really tiny workmate, or that’s one MASSIVE bowl! How big was the lathe???
I think the bowl is about 15inches across, I'll check it later. It's a record CL3, older green one they do them in a horrible greyish color now.Either that’s a really tiny workmate, or that’s one MASSIVE bowl! How big was the lathe???
Yes it can, much nicer than throwing something away, definitely adds character.sometimes a repair can add to the look of an item and make it more interesting.
A friend asked me to make some small handrails for his steps so I made a start today by cutting some 5mm 5083 Aluminium.
A view of the plasma doing its thing. The view is through the Optrel Crystal but I still can't get a true to life view, the camera seems to auto adjust no matter what I do and it doesn't come out anywhere as near as clear as you can see with the eye.
Hopefully I will get a chance this week to bend the tube and weld things together and then get it into the powder coaters.
A kydex press + a "first attempt" at a sheath.
Heated to 150c in the oven.
Note to self: needs a silicone sheet on the baking tray, otberwise it sticks!
The press is two squares of plywood + three thicknesses of poundshop "camp sleeping mat" on one side (for a flat backed sheath).
Clamp the knife between the plastic sheets and leave to cool.
It *sort of* welds together - will probably be better when i get the heating process down pat.
The brown marks are dried resin i think - as i just used a small offcut ive
had floating around in the shed for a while as a mixing board.
I need to put some rivets around the edge of the knife, and then cut to shape.
But...
Considering i have around 60sq m of the stuff, i can afford to practice.
Could you warm a line along a sheet with hot angle iron , fold the sheet so there is no riveted seam on the back of the knife . Clamp tight as before , then when it's been set & gone cold set a router and ledge up side down and use the router to trim a 11 mm margin bigger than the blade from the point to the ricossa ( sp ? ) drill thread holes every 6 mm , use a blunted chisel to join the holes and sow it up tight with a waxed black linen thread or 80 pound woven Dacron line ?
What about a wedge of contrasting wood put in, bottom bow tie turned with the wedge to bowl shape, but the upper one made of ebony, internally turned but the outer carved as a bow tie?Managed my first 2 bow-ties today. This is a bowl a turned about 10-15 years ago, was from a section (or cookie as the yanks call them) of sycamore. Not surprising it split, so insert 2 oak bow-ties to stabilize then I'll cut them back and tape it up then I can pour some resin in, probably use some copper powder in it. I'll probably throw it back on the lathe and re-turn it once done, maybe cut it a bit deeper.
Sounds like an interesting option, but I've glued the 2 oak ones in and taped it up for resining so I think this time, I'll go with resin.What about a wedge of contrasting wood put in, bottom bow tie turned with the wedge to bowl shape, but the upper one made of ebony, internally turned but the outer carved as a bow tie?
Maybe it's just me, but the pictures aren't displaying!
First real job for my TIG, a tensioner for fencingwire, absoutely impossible with my MIG welder of course.
15mm steel tube took galvanising off on the lathe first.
Worked really well on the first two, but got overconfident and snapped the third wire, just before it got too dark.
