Hi all
Before I kick my new/unused/cr*p Cosmo 150 welder again should I try this ?
Reading the other mods [ I have done the strap and new transformer mod ] it seems the 24volt transformer mod on it's own does not give enough fine control over the wire speed and 24 volts instead of 18volts max ?
The person doing the Maplin PWM speed mod is only using 12volts to drive the Maplin unit ?
So why not wire up the 24volt transformer to give only 12volt ? that would increase the sensitivity at the lower end on the speed scale at the expense of losing maybe 1/3 of the maximum speed [ 12volt instead of a reported 18volt in unmodified form ? ]
If this may work how do I wire up a 0 - 12 0-12 transformer to give me max current at 12volts ?
I only want to weld 1mm - 2mm m/s so can afford to lose some wire speed ?
regards Paul
regards Paul
