Hood
I am obsessed.
- Carnoustie, Scotland
@daedalusminos I will be extremely interested in how you get on with the Prusa. Very impressed with their QA/QC systems.
Is that a spooling issue because it’s cheap PETG or a feed issue with the Bowden tube?
I started building last night very impressed with quality and presentation of the parts. The documentation is excellent - full colour printed assembly book which is also available online with other customers comments/problems. All parts individually bagged/boxed and well identified and assembly is a joy (except for one hiccup which cost me an hour).@daedalusminos I will be extremely interested in how you get on with the Prusa. Very impressed with their QA/QC systems.
The filament is somehow jammed on the reel. It has done that since day 1 and it seems there's nothing I can do. I keep an eye on it, make sure the path is clear, I fitted an outrigger support guide which helps the filament path tremendously but once in a while, the filament coming off the roll gets stuck under another filament still wound on it.
There is probably a "solution" and it probably involves rewinding the reel (!) but the most cost effective option is to buy one that has been carefully wound to start off with. Hence my admiration for the PRUSA method which looks perfect. My reel already looks like a birds nest...
Though now I think about it, the only topological solution is that somehow the reel started off with the loose end underneath a coil and its always been like that. I might change reels (bored with black) and see if I can find an overlap.
Nice. I am already lusting after that precise model.
This diy plastic printing facility is a bottomless pit of opportunity (mixed metaphor intended).
Been knocking up some inserts for plastic storage boxes.
Spiral print (vase mode) takes no time at all (hardly) and with 0.8mm side walls in PETG, these boxes are tough! I have dozens of those Allit boxes and these inserts make them dead handy. They are available of course but in set sizes and £4 each! I can make these 4 square (although two square inserts is enough to give 4 compartments). I can make a double length oblong and next batch will be half height for double depth etc...
Plus, no need to ad the picture but I have just printed out a replacement battery cover for one of my digital calipers (12 minutes).
Overnight I'll be printing out a replacement bottom cover for my MacMini which needs a deeper base for a fan conversion.
Me too and after watching their video posted above, I'm going to try their filament too.
Just spent a sleepless night worrying about the reel jamming up as it comes off the spool. Happens fairly often with the black PETG which iirc was the very cheapest possible "no name" product. A false economy when you consider a fair proportion of the "cost" is the printing time itself.
Even if there is the briefest pause in filament feed, the entire print can fail, sometimes quite spectacularly.
Have you thought of trying of making rows of hexagonal holes in a printed strip that's just tight enough to hold the hex bit securely . A strip is easier to hold and extract a bit than go fishing in a small box especially when your hands are cold or if you have bratwurst sized fingers. . Plus if you do them in strips of 5 or ten it a doddle to see how many you have and if you upset the box you don't have to spend ages picking up individual items , just easily seeable strips of them .
Similar to this strip
The eldest (13) beat me to designing and printing. I pointed her at tinkercad and half an hour later she had knocked up a label with her name and form number for her school bag, exported it as an STL, sliced and printed it. She's working on mkII now
The youngest has just got her new school login as she is in year 7 next year, high school to people like me where you had infants, juniors then high school. She has one subject where she will use Creo Parametric 3, a 3D CAD package I had never heard of before I searched, but seems to be used in aerospace a lot. First project is a passive phone speaker made from recycled materials.
I'll have to get into CAD, I have a few things I want to knock up for the workshop. Fusion360 here I come....
