Hi
I'm new to posting on this site - hopped over from the Landy site
Currently learning to spray paint in preparation for starting on the bodywork of my Landrover. Practicing on my garage door at the moment, although have done the chassis.
Equipment I am using is an old compressor - about 120 L and up to 12 bar pressure so man enough for job. I was given the gun which is a Comaria Suction (called semi professional!)
The paint I'm currently using is cellulose based "QAD Matt Enamel" and I will be finishing with QD Polyurethane Enamel.
Im thinning with cellulose Terosyl General Thinners which I was told was cellulose. I have a couple of problems and because of all the variables find it hard to work out what I am doing wrong.
1. Occassionaly get a matt grainy finish that rubs off. Diluting paint by about 10% what happens if I dilute more?
2. The fan width is fairly narrow so I'm tending to end up with a stripey finish - how can I get a wider fan for large body panels
3. In my instructions I cant find advice on how to position the Horns should they be horizontal or vertical if I am painting horizontally. Not entirely sure what they do.
4. I seem to get through a lot of paint - just done a small area of the garage door about 2.8 m2 using about 1/4L of paint. How do I get less wastage.
Have played around with pressure - started at about 40Psi,but have dropped as low as 30psi - Im wondering whether I have too little pressure?
Will be grateful for any advice/thoughts
Many thanks
Jonathan
Many thanks
Jonathan
