how thicks that plate , looks a bit cold / too much wire . although looking at the end craters its prob just lack of power and having to wait for things to happen , tell us more about the plate and the power ,, have you a selection of plate to play with .
I forget to say that i have 220volt power source (not 120volt)whats the back of the plate looking like ,,, try a wee bit less wire and have a go at a joint , your off to a great start.
gives you a bit more punchI forget to say that i have 220volt power source (not 120volt)
Can it effects settings?
If your welding inside you could get away with 14 or 12 your runs look quite good keep practicing padding beads and then start filling up a tee plate
Tnx, i will do for sureIMO, They are pretty good for 0.03 inch wire, the first one is a bit cold though. If your machine allows it, try to add and extra 1 or 2 Volts.
