If you call that thin metal ... As above, garrison, pferd, tyrol, etc... All good make will do, look after them and they will last !
He is stick welding![]()
Play with pulse settings on your welder, you put far less heat into the thin piece allowing to get the thicker piece to melt so you can wet it onto the thin piece...I play with the on off switch instead...some like a foot pedal to make sure they get the power they need...
