The_Yellow_Ardvark
- Going Away.
great in winter aren't theyGot one of those as well.
Shatteringly so.great in winter aren't they![]()
Go away, go a long way away, then repeat.Best be asking Nell about that village pump , she stands by it apparently![]()
Might I recommend you take a look at Milwaukee Fixtec Nuts?Picked a new grinder key up from toolstation
Will be interested to see the guarantee
got to work to discover my boss had ordered the wrong flap discs...
Despite @8ob complaining Milwaukee stuff is too expensive he's ordered a big box of them and the previous time I was in Surrey he was giving them away to anyone who came into the yard he loved them so much.
Dare I say I may have swapped my 9" angry grinder over to use one as needed to change the disc in a hurry to cut through a P38 chassis and couldn't find the spanner. So some vice grips got it off and then a nut swapped in its place. Hasn't come off yet![]()
I've got a cordless Milwaukee grinder and I'm not a fan of the fixtec nut, maybe I've just got weak fingers but I always find it's too tight to undo by the tiny loop, often end up with a pair of pliers on the handle.
You can get DC clamp meters but they're generally a fair bit more expensive.
https://www.tester.co.uk/uni-t-ut204a-digital-clamp-meter
A drawing board T square perhaps ?
Is that a brass edge set in the workface .. if so it could have been part of a Roto Ring drawing set where the pens had open ink reservoirs at the tip end , they were a common sight in a small drawing office in the 60's & 70's the brass strip set in the straight edge stopped you making an ink bridge between the paper & the wood .
The rubbing strip on the stock leads me to thinking this
Was offered these heavy box section from a mobile hoist, should come in handy for something
