Rowan Sylvester-Bradley
- Newmarket, Suffolk, England
I need to add a new switch to control the motor on my small lathe. The motor is a single phase motor of 0.33 HP, 2.8 amps full load, 1450 rpm. I need to be able to start the motor in forward and reverse directions, and to stop it. I also need a mushroom emergency stop button. It should also have a NPR function. The best way to achieve this seems to me to be a small panel with a push button for Start Forward, a push button for Start Reverse, and a mushroom button for Emergency Stop. Can I buy a control like this? Where from? Or do I need to make it? If so, can you suggest a schematic? Presumably it will need a contactor or two.
I hope someone can help me with this problem.
Thank you - Rowan
Thank you - Rowan
