Ardy , there are also differenced in the tips of engineers electricians & cabinetmakers screw drivers wrt the angle they should be ground to as well as the width of the screw head slots . These days the tool manglers just have one set for everything and frequently tear the slot shoulders out .
Those pin pushers are expensive .. the last one I purchased about six years ago cost me in the region of £18 brand new ...had a hard plastic impact resisting handle too just in case a tapommeter was needed & a precision brass body .
Do any of them have a magnetic anvil tip to hold the pins in the barrel on the way to putting them in the material?
Not so much made more than restore, this is a table top for the fly press, the dark patch is where it's been bolted to for the last 6/7 years, was initially stained in red which I wasnt keen on, so sanded right back and its had about 4 coats of danish oil so far, I'm trying to get a shiney effect but iv no idea if I will achieve this, wood is mahogany any tips?
Difficult to achieve a mirror type glaze with danish oil but you can get a fairly high shine. Keep applying till the wood won't soak up anymore oil. Then you need to apply a nice thing even coat, foam pad or brush is best, then let it dry in a dust free environment.Not so much made more than restore, this is a table top for the fly press, the dark patch is where it's been bolted to for the last 6/7 years, was initially stained in red which I wasnt keen on, so sanded right back and its had about 4 coats of danish oil so far, I'm trying to get a shiney effect but iv no idea if I will achieve this, wood is mahogany any tips?
dirty float you should know better![]()
Picky ............................. it's not even dry ..he's about to clean it .. he told me so a few seconds before he took the photo .
