But the olive, of whatever material, is totally enclosed by the rest of the compression fitting so how can it burst? I'd be interested to see details of that risk if you have any to cite.
Its not enclosed though, its deformed to fit the space
I will dig my LPG books out and find the regulation later this week
It's enclosed. I think that you are confusing the corrosion / reaction issues perhaps ?
what about the rest of copper pipework to and in the appliancesHave to use brass with LPG, if the regulator fails copper olives could burst
I know how an olive works thanks.
If it was as tightly enclosed as you are suggesting then they would never leak, except they do
I was having a 'mare once with some cheap compression fittings, the bloomin' things just would not seal up...nipped up, rumped up, new olives...it wept....I wept.
I text a plumber I knew asking for advice.
"10 wraps of PTFE round the olive" came the reply.
Worked a charm...but I'd use solder or push fit these days, I avoid compression fittings if at all possible.
