johnrev
- Norfolk, UK
Hope I'm not being a pain but am hoping eddie49 or mike109444 or one of the other electronics wizz's on here could answer a few questions about transformers for me.
I know MIG is a CV process and that a mig transformer uses a tapped primary to adjust power settings (voltage) and I know a stick welder uses a CC transformer which generally has a shunt controled output power arrangement (amps).
1) Are there other differences between the two types of transformer? The one from my SIP 140 looks massively larger than the one in my Topmig 150 even accounting for the shunt system.
2) Could a transformer from a stick set be used as a CV mig power unit if the shunt is removed and the primary is fed via a PPM type supply rather than via the usual tappings?
3) I assume the secondary of the stick unit would be too high a voltage for mig so could this be reduced by removing some of the secondary winding?
4) How would this affect the output power ie if the stick machine was, say, 140amps at 60v would it be correspondingly higher output at 30v?
All this is just something I've been musing about and may not actually try it but you never know how bored you might get eh!
Thanks
John
Thanks
John
