jerrytug
- Isle of Wight
It's gripping a big hex in a holesaw, could that jam it?
It appears to have holes for a kind of C-spanner ( not supplied). In the 2-dot section.
I cant even work out which section does what.
I need to drill some other holes apart from 50 mil, hopefully now.
Got no Stilsons big enough to grip it.
Any suggestions please chaps? I have put tipex dots on the different bits. The bit with the one dot is just sort of jammed on, but it does have a grub screw hole ( screw not supplied) and it might be the section you are intended to grip with your other hand?
Stupid thing
. I made a temp small rod with a thread on to fit that hole in the one dot bit to brace against with my thumb until I can get/ make a C spanner.
