Depends how big it is, what material etc etc. I have a pricing spreadsheet i use for plasma which is pretty accurate to be honest. It works on cut cm, pierces (holes) and overall area of your item.
That'll give me a figure i can adjust up or down but with out knowing any of that about yours then I wouldn't even guess. Pm me if you want and I'll stick it in but it won't be till the evening as I'm out working all day
Just got a cardboard template for it I’ll get a picture thoughLaser cutters are £100 minimum order down here
have you got DXF files? Ping em over I’ll take a look and give you a price to Plasma them.
Ah right, you’ll end up paying for that at a laser cutters, most hate having to do any actual drawing or work on files.Just got a cardboard template for it I’ll get a picture though
If it ends up costing to much I’ll just cut it with a grinder was hoping to have it done properly though as I was going to do a run of them if there was enough interestAh right, you’ll end up paying for that at a laser cutters, most hate having to do any actual drawing or work on files.
Send us the picture I’ll have a lookIf it ends up costing to much I’ll just cut it with a grinder was hoping to have it done properly though as I was going to do a run of them if there was enough interest
Will get you one tomorrow I’ve took it to my local and there doing one in 4mm aluminium for 15£ so I’ll seeSend us the picture I’ll have a look
Send me a pm with your email and I’ll do it when I get home. I’ve a few versions. They all spit out roughly the same number - it’s a rough guide but I tend to follow it closely. It makes assumptions like each part is out of a rectangle and doesn’t allow for nesting. If you leave it or adjust it down it’s up to you. With me it depends on jobThat would be really useful if you could ping me a copy over James?
I’m just pricing things based on the time I have to spend importing the dxf and then the machines run time.
That’s alright for laserWill get you one tomorrow I’ve took it to my local and there doing one in 4mm aluminium for 15£ so I’ll see
I’ll pm you some pictures to get a price to cut 10-20 out of 2mm msThat’s alright for laser
Just need to finalise the designOf what?!
What’s pictured above but I’ll finalise the design tomorrow was just told I need it in a dxf to be plasma cutYou don't draw a DXF, DXF is a drawing exchange file, exported from most CAD programs and is used to transfer drawings between different CAD programs, laser cutters and the like use it as well.
What do you want drawing?
I was going to draw it back out better tomorrow as it’s finished design was just looking for someone to do itYou need a paper drawing with accurate measurements, angles, hole centres and hole size before you can get someone to draw it.
Do an technical/engineering drawing on some graph paper with accurate dimensions.
